2006 YZ250F coolant tank
There are no brackets on the subframe to bolt it to, but you could wrap some metal strap material around it, and go with that.
I'm using a KDX tank, smaller but usable.
That sounds like a pretty good idea. Gotta see how to mount it. I saw that Motion Pro has an aftermarket one.
Look up a Honda CRF250X tank as well, it's two mounting 'ears' would easily attach to the subframe with a pair of Adel clamps (see below)
CRF <a href='https://thumpertalk.com/link/click/1133/' rel='nofollow noopener' data-ipsHover-target='https://thumpertalk.com/index.php?app=autolink&module=links&controller=content&id=1133' data-ipsHover target='_blank' data-autoLink>coolant</a> tank.jpg
Edited by mlatour
Less than$20 from ace hardware. I looked up overflow tanks and this was the best one I found. If you’re mounting in on the backside of the radiator like a lot of the ones I saw. You’re defeating the purpose blocking air going across your radiator.
Overflow radiator hose goes to the bottom and the top just dumps on the ground.
  • Like 4
EDIT:
first glancing at the pics without seeing how the hose were plugged I had doubts but re-read carefully and it makes sense.
Quoted:
Indeed a simple design that doesn't take up much space or weight :thumbsup:
I had removed the OEM coolant tank on my CRF to save weight but just might install one of these...
Edited by mlatour
I don't see how this could allow the coolant to be drawn back into the radiator when the engine when it cools. Not unless there is something I'm missing. I do like the idea though.... small, light, you don't need a large overflow tank in most cases.
The OVERFLOW hose goes to the bottom. So when things cool off, the radiator creates a suction and sucks the fluid back in...from the bottom of the tube. Topologically it's exactly the same as a regular overflow tank.
The overflow tube goes to the bottom of the "tube", top is the exit/overflow.  Works just like a regular overflow tank.
Got it now... excellent idea! My mind is slow moving this morning!
Updated it. I didn’t like where it was before. Where it is now, it’s completely out of the way and sight.
