shock lowering
how much can a shock be internally shortened?   Am I only limited by the spring length?
In theory, yes.
Practically you sooner or later will introduce very bad suspension performance due to the lack of travel.
The max. distance I shorten suspension for riders is 30mm, which is a 10mm spacer inside the shock.
1 hour ago, Vietze said:
In theory, yes.
I am doing a street tracker bike and want to lower the front and rear a fair amount.  will I have to work with the linkage rate along with lowering the shock?
I will be using much heavier spring rates due to the lowered suspension  (shim changes too).
Edited by cj_wai
