Throttle valve “slide”
Will a 04 CR125 throttle valve work in a 04 YZ125 carb?
the YZ slide is $150-$200 while the CR slide is only $70
thx
thx
Insure they are the same carb and yes.
I thought a 04 CR and 04 YZ both came stock with the TMXx Mikuni carb?
I am trying to decide to either put money into the stock TMXx carb, or just run a Mikuni SBN38 carb on the engine...
Sorry, I’m not up on what Honda used per year and Bike. If you researched, and they are same carb and model, than they should be interchangeable with each other. I know different Moto companies charge more or less for interchangeable parts.
Thx for your help...
make sure they run the same number as well... don't put a 4 in a bike designed to run a 7 for example
