IMS 4.0 install problem
2002 DRZ400E.   Hey all. I'm having an issue with my new IMS 4.0G tank. I have it installed now (took 1 1/2 hours to get the Emperor rad guards and the IMS tank to bolt together well) but the seat will not fit far enough up for the rear seat bolts to line up, they are still about 3/4" away.
39999392652_90b9a99975_c.jpg20180201_160931 by Rob Ert, on Flickr
The plate doesn't really adjust. And I was hoping to get some input from anyone that has installed the same tank to a 400E before I cut the seat plastic
26158653678_23c9e99077_c.jpg20180201_161328 by Rob Ert, on Flickr
And before anyone asks, yes I have hit it aggressively with a mallet...:smirk:
I have had to lengthen the seat hook on more then a few plastic tank installs...  tankhook.JPG.0de00f55365689042b03da99f87c3f49.JPG
Is there 2 models one for E and one for S,SM?. And you have the correct one?
Yes I have the correct tank for the E model. The issue isn't that the hook won't reach the seat it is that the seat hits the seat hook too soon. If I cut the plastic under the seat it will allow the seat to move up another 3/4" or so and then the bolt holes will align. Not a big issue just wanting some input before I take out the sawzall.....
I had the same problem with my Acerbis tank. it isn't the length of the metal tab its the width. measure and grind it down to the proper width and it will slide forward enough for proper fitment. see before and after pics below.
  • Similar Content
    • By Eric Schrader
      2007 Honda CRF 450-R which is set up for desert racing (Track/desert) complete with quick fuel dry break gas tank, extra 4 gallon dump can and stand and a complete extra front wheel. The racing quick fuel system alone costs $1,000 new on this bike and takes 91 octane pump gas. The bike has an 18" rear tire with a heavy duty setup (see description for details). The bike rips across the desert and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Suspension is set up for 6'4" 175lb rider with a tall seat configuration, but the stock seat is included as well. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head, Carb just rebuilt, bike is prepped and ready for the season. Starts in 1-2 kicks always. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker registration r with spark arrestor and original title. 2nd owner.
      Extremely detailed writeup/configuration of this bike:
      GPR V4 Stabilizer - 05-08 Honda CRF450R Red/Black- Fat Bar Kit  Renthal 1 1/8" FatBar Ricky Carmichael High Bend Tanium Factory Effex Grip Donuts Honda CR Pro-Taper Pillow Top MX Grips Black/Grey/Red ASV unbreakable clutch and brake levers Air/Fuel
      IMS 3.2 Dry Break Ready Natural gas tank IMS Dry Break full receiver No Toil Pre-Oiled Air Filter  Carb/Ignition/Engine
      Tokyomods Carb Mod Tokyomods 10 Map Ignition System OEM SS/Ti Head valves, Precision Concepts (~20 hours on it) Acerbis lightweight polypropylene skid plate Tokyomods Mechanical Camchain Tensioner Pro Moto Billet Spark Arrestor endcap w new screen PMB-01-1104 Drive
      Primary Drive Rear Steel Sprocket 48 Tooth  Primary Drive Front Sprocket 14 Tooth  Primary Drive 520 ORH Gold X-Ring Chain 520x114 Polisport Chain Guide Black  Polisport Chain Slider Black Polisport Chain Roller 42mm Black - Upper  Rear Wheel
      D.I.D 18X215VS01H Dirt Star Silver 2.15x18 OEM Profile Rear Rim Bulldog Splined Spokes Bridgestone Ultra Heavy Duty Motorcycle Tube 110/100x18 110/100x18 Maxxis Maxx Cross Desert Intermediate Terrain Tire (60% tread) DUAL Motion Pro LiteLoc Rim Lock 2.15" Motion Pro Armor Rim Strip Tape 18"/19" Balanced using motion pro weights Front Wheel
      Bridgestone Ultra Heavy Duty Motorcycle Tube 80/100x21 90/90x21 Maxxis Maxx Cross EN Tire (100% tread) Motion Pro LiteLoc Rim Lock 1.85" Motion Pro Armor Rim Strip Tape 21 Motion Pro Rim Lock Dampener Balanced using motion pro weights Suspension
      Precision Concepts suspension rebuild w/ Factory Mid-valve Mod (rebuilt front/rear suspension last year) Seal Savers Fork Covers - Inverted Forks 44-50mm Fork Tube, Long, Red SDG High Foam Seat Motion pro kick stand Carb Settings:
      Starter jet k72 Main jet k178 Needle jet Slow jet k45 Pilot screw 2 1/2 turns from out Jet Needle NJYR. Clip 3rd from bottom Slow air jet k100 Twin Air Pre Oiled Air Filter Radiator
      Oversized Outlaw 1.8lb cap Cycle Logic Engine Ice Brakes
      New rear Tusk Stainless Steel Typhoon Brake Rotor New Braking Race Sintered Compound CM46 Brake Pads  Tusk Rear Motorcycle Steel Braided Brake Line Standard Length Red (incredible braking power) Galfer Front Steel Braided Brake Line Standard Length Red Motul RBF 600 Racing Brake Fluid DOT 4 Plastics
      Acerbis Replica Plastic Kit Original 07 (1 year old) Acerbis Lower Fork Cover Set Acerbis Front Number Plate White Rocky Mountain Attack Graphics Custom Blitz Full Coverage Number Plate Backgrounds Red/White - 2007 HONDA CRF450R Extras:
      Extra OEM complete front wheel/bearings/dust caps Bridgestone Ultra Heavy Duty Motorcycle Tube 80/100x21  80/100x21 Maxxis Maxx Cross Desert Intermediate Terrain Tire (60% tread, a few years old) Motion Pro LiteLoc Rim Lock 1.60/1.40 Motion Pro Armor Rim Strip Tape 21 Motion Pro Rim Lock Dampener 4 gallon IMS Dry Break Dumpcan with Probe (IMS 218351-WP) needs seal kit IMS dumpcan stand (218391)  OEM Honda service manual New packaged Engine parts Oil filters/seals OEM radiators Complete set of extra used plastics OEM seat Pro Taper EVO 1-1/8" Oversized Handlebars, Color- Magnesium, Size- CR High Stock ECU More
        Updated to include Dry break dump can, can stand, extra front wheel and updated details about the bike. Extra parts photos
    • By 2stmakemesmile
      My beater/chase the kids/farm bike sprung a leak in the 30 year-old plastic tank.  I found some exact matches on ebay for cheap... but as we know the stickers no longer stick and the tank looks lame (to me) with out some glitter on there.  So, I decided to go for a steel tank since I rarely lay it down and don’t take good care of it anyway.  So I found a steel tank listed as from an XR600R.  I knew it was not from that bike, but from the pics I knew I could make it work with some custom mounting.  It came today and looks like it’s going to be easy to do.  My question, can anybody say for certain what this tank actually came stock on?  I’ve found pictures that match the decal, but not the mounting flanges.  I’ll post a picture or two once I’m done so you guys can drool at my ‘race ready’ XR 🤣
      Used 4 Gallon Clarke tank off of my 2013 498RR.  I know it fits other Beta models but I'm not sure which ones.  Comes with its own petcock.
      $150 + shipping, PayPal preferred
      This is off of my 2013 498RR, I know it fits other models but this tank has the mounts for the newer (2014 + ) plastics.  Don't know if the earlier plastics line up or not.  It uses your stock petcock, so it doesn't come with one.
      $125 plus shipping.  PayPal is my preferred payment method.
    • By geno11x11
      While fueling my XR650 the other day, the IMS fuel cap came apart and the smaller piece dropped into the tank. Doing a little research, I found two styles made of plastic: (1) with 6 squared off cogs (2) with 5 rounded graceful cogs - pics attached. Mine is the former.
      Yes, I can buy a new one, but if I can just buy a seal that would be great. Online pictures of a new cap show the same two pieces that I still have. The question is, what holds them together? Did it break or does the seal, a clip, or something else (maybe in the tank as well) hold the two pieces together?
