2001 Gas Gas 321 TXT Rear RIm
So in the middle of Mid-Winter preventative maintenance, I discovered a crack in my rear rim.  So I need replacement.  Thinking I was cool I ordered an Excel Rim.  In the process of lacing it up, I discovered that there are different drill hole patterns for the spokes.  I think they are called left hand and right-hand drilling.  Turns out the Excel Rim is right hand drilled and the Gas Gas is left hand drilled or visa-versa.
Anyway, the GasGas rim is tubeless, but since I'm using a Tubliss system I don't need a tubeless rim.  SO does anybody know where I can source a 18x2.15 rim that will fit a Gas Gas drill pattern??
Nope, a tubeless rim would work, it's just that I could use either.
That link is the correct part / number
Called him and have a rim on the way.  Thanks
AWESOME!!! Glad to hear that worked out for you!!
