Replacing 300RR Rear Caliper
I have managed to destroy my rear caliper on my 2015 300RR. Long story short, there is some scarring near the cylinder where the caliper piston slides in and out. I had thought I could salvage the situation by replacing the piston and the seals. The seals held pressure for anout an hour and a half today. After that, brake fluid was leaking and and I had lost all pressure on the pedal.
I'd like to get a new calipered ordered ASAP so I can be riding later this week. I need some help determining cross reference of this caliper to other bikes. I've searched this forum and didn't get a concrete answer so I decided to create a new thread.
Is the rear caliper on the Beta the same rear caliper as that of the ones found of Japanese bikes? I use OEM Kawi pads for the rear so, I suspect yes. Here's whats interesting though, when I peruse Rocky Mtn ATV's OEM Parts catalog I am comparing the rear caliper from the Honda to the Kawi part. Honda shows as $146 while Kawi shows as costing $168. If they are the same caliper, why the difference in OEM cost?
All these are the same if thats any help
Part # 2503066000
BRAKE SYSTEM (RR 2T 250/300 Racing) (2015)
BRAKE SYSTEM (RR 4T 350) (2011)
BRAKE SYSTEM (RR 4T 400/450/520) (2010)
BRAKE SYSTEM (RR 4T 400/450/520) (2011)
BRAKE SYSTEM (RR 4T 350 EFI) (2015)
BRAKE SYSTEM (RR 4T 350/430/480 Racing) (2016)
BRAKE SYSTEM (RR 2T 250/300 Racing) (2016)
BRAKE SYSTEM (RR 4T 350 Factory) (2014)
BRAKE SYSTEM (RR 400/450/520 Factory) (2011)
BRAKE SYSTEM (RR 4T 350/390/430/480) (2016)
BRAKE SYSTEM (Xtrainer) (2016)
BRAKE SYSTEM (RR 4T 390/430/480) (2015)
BRAKE SYSTEM (RR 4T 350/430/480 Racing) (2015)
BRAKE SYSTEM (RR 2T 250/300) (2015)
BRAKE SYSTEM (RR 2T 250-300) (2016)
BRAKE SYSTEM (Xtrainer) (2015)
BRAKE SYSTEM (RR 2T 250/300 Racing) (2014)
BRAKE SYSTEM (RR 2T 250/300) (2014)
BRAKE SYSTEM (RR 4T 350/400/450/498) (2014)
BRAKE SYSTEM (RR 4T 450/498 Racing) (2014)
BRAKE SYSTEM (RR 2T 300 Racing) (2013)
BRAKE SYSTEM (RR 4T 350/400/450/498) (2013)
BRAKE SYSTEM (RR 4T 350/450 Racing) (2013)
BRAKE SYSTEM (RR 2T 250/300) (2013)
BRAKE SYSTEM (RR 4T 350/400/450/498) (2012)
BRAKE SYSTEM (RR 4T Factory) (2012)
BRAKE SYSTEM (RR 4T Cross Country) (2012)
