Suzuki drz400sm rear sprocket need help!!
Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
Check and see what hub it is. My buddy’s DRZ 400 has a KTM hub (stock!) and required a KTM sprocket.
That's not a DR-Z400 hub so DR-Z400 sprockets are not likely to fit as you discovered. If it's a cush hub its probably KTM.
Edited by ptgarcia
hearsay those with cush hub is direct imports from japan ?
I see the OP is not from the US so it is possible it's an overseas spec factory Suzuki DR-Z400 hub.
Thank you guys for such a quick reply how do I find out whether it is a cush hub , but I know that it has pieces of rubber inbetween the sprocket hub and the wheel and most probably the bike is an import from japan cuz it had all the solenoid stuff and the air pump connected in the bottom of the carb , so is mine a cush hub
That is the definition of a crush hub. The rubber makes the power delivery smoother.
EU models has the solenoid as well but not cush drive ,any pics of your carb ?
Edited by Aimara
You need JTR822 or Japanese OEM Sprocket -- 64511-15D50
Thank you guys I think the JTR822 has the correct internal diameter as said by Aive1 cuz the original drz sprocket didnot fit the internal diameter but only by a small amount though .
Aimara , My carb is the Mikuni BSR36 pics attached below , it originally had the air pump motor underneath the carb I recently removed it and installed the JD jet kit with the 3x3 mod
