Guest Posted February 9, 2018 Hi I have a 2017 ttr230 and I ordered a headlight and switch but I need a wire harness unless if anyone knows how to wire it a Different way. https://m.ebay.ca/itm/Universal-Dirt-Bike-Motorcycle-Vision-Headlight-Head-Light-Street-Fighter-Lamp-/332143818141?txnId=1501555486014 https://m.ebay.ca/itm/7-8-39-39-22mm-Motorcycle-Handlebar-Horn-Turn-Signals-High-Low-Beam-Headlight-Switch-/142470679622?txnId=1497984268004 Share this post Link to post Share on other sites
jamesm113 My Rides (2) Posted February 10, 2018 Sub'd. I'm planning on installing a Baja Designs halogen headlight on my 05 TTR230. A friend did a similar mod on his Honda CRF230. Rewound the stator and recommended the TrailTech regulator as it has a "delay shut off" circuit that leaves the headlight on, even after the engine stalls. I think he just jerry-rigged his wiring together... Share this post Link to post Share on other sites
Guest Posted July 25, 2018 Hi I got my trail tech x2 head light and was wondering about ways I could wire it to my 2017 yamaha ttr230 with out any problems Share this post Link to post Share on other sites
BOAB Posted July 26, 2018 https://www.trailtech.net/instructions and if that doesn't help: https://www.trailtech.net/tech-support/ Share this post Link to post Share on other sites
Wilderness Posted August 7, 2018 Here is mine, i just ordered the LED and wiring harness from amazon. easy install just had to remove about 5ft of wire from the harness (too long) and i made a custom bracket to mount in to my bar clamps! works good! https://www.amazon.com/AutoSonic-Wiring-Harness-included-Warranty/dp/B078PGXF9P/ref=sr_1_6?ie=UTF8&qid=1533679426&sr=8-6&keywords=led+wiring+harness i believe this is the harness i got Share this post Link to post Share on other sites
Shockwave95 Posted August 22, 2018 I am also looking at getting the X2 kit from Trail Tech. To make it work, do I have to up the watts fo the bike? Change the batterie? Share this post Link to post Share on other sites
Shockwave95 Posted August 22, 2018 Hi I got my trail tech x2 head light and was wondering about ways I could wire it to my 2017 yamaha ttr230 with out any problemsHey, Did you got it install? If yes, can you tell us if you had any issue? I am looking at getting one also. Share this post Link to post Share on other sites
Guest Posted August 22, 2018 (edited) 1 hour ago, Shockwave95 said: Hey, Did you got it install? If yes, can you tell us if you had any issue? I am looking at getting one also. Hey I installed it with no problems make sure you order the trail tech universal switch and so you won't have to wait when you figure out that it doesn't come with a switch https://www.trailtech.net/accessories/electrical-accessories/3600-pwh then I converted the not so bright halogens to LEDs that are decently bright by crimping the wires together inside the headlight http://stores.advmonster.com/h3-mesh-monster-led-headlight/ and a http://stores.advmonster.com/m5-led-spot-for-trail-tech-x2/ and then routed the wires to the battery along the frame under the gas tank only problem I have is that I can't figure out how to wire the kill switch, if you have any other questions just reply Edited August 22, 2018 by Guest Forgot some details Share this post Link to post Share on other sites
Shockwave95 Posted August 23, 2018 Hey I installed it with no problems make sure you order the trail tech universal switch and so you won't have to wait when you figure out that it doesn't come with a switch https://www.trailtech.net/accessories/electrical-accessories/3600-pwh then I converted the not so bright halogens to LEDs that are decently bright by crimping the wires together inside the headlight http://stores.advmonster.com/h3-mesh-monster-led-headlight/ and a http://stores.advmonster.com/m5-led-spot-for-trail-tech-x2/ and then routed the wires to the battery along the frame under the gas tank only problem I have is that I can't figure out how to wire the kill switch, if you have any other questions just reply[/url] Thanks for the fast reply. My local shop told me that I could not install a light kit without some electrical upgrade power mod a new battery. Running it for hours it will not kill your battery? Looks like I will put the order in. Can you post a pick of what il looks like on your bike? Share this post Link to post Share on other sites
Guest Posted August 23, 2018 (edited) 16 minutes ago, Shockwave95 said: Thanks for the fast reply. My local shop told me that I could not install a light kit without some electrical upgrade power mod a new battery. Running it for hours it will not kill your battery? Looks like I will put the order in. Can you post a pick of what il looks like on your bike? Depending on how many watts your stator is mine is a 65w so if I ran the high beams on for a long period of time it probably would kill the battery because each stock bulb is 35w and running high beam would be taking 70w so that's why I switched to LEDs and if you look below or whatever on my last post it should have a picture of the bike on that Instagram link if it wasn't embedded on to the post also what kind of bike do you have? If you run low beam you will have no problem if you don't convert to LEDs if you have a ttr230 Edited August 23, 2018 by Guest Share this post Link to post Share on other sites
Guest Posted August 23, 2018 (edited) Edited August 23, 2018 by Guest Link was wrong Share this post Link to post Share on other sites
Shockwave95 Posted August 23, 2018 Depending on how many watts your stator is mine is a 65w so if I ran the high beams on for a long period of time it probably would kill the battery because each stock bulb is 35w and running high beam would be taking 70w so that's why I switched to LEDs and if you look below or whatever on my last post it should have a picture of the bike on that Instagram link if it wasn't embedded on to the post also what kind of bike do you have? If you run low beam you will have no problem if you don't convert to LEDs if you have a ttr230 I have a 2006 TTR 230, so I must assume that my stator produce 65w also. Thanks a lot for your help. I am new to this game. Share this post Link to post Share on other sites
Guest Posted August 23, 2018 I have a 2006 TTR 230, so I must assume that my stator produce 65w also. Thanks a lot for your help. I am new to this game. I was too but I figured it out and yes you have a 65w Share this post Link to post Share on other sites
