XR600 seal Identification needed
But there is only one of these seals in the kit and 4 different green ones that look like valve seals? and the center hole in it is about an 1/8th of an inch in Dia.?
Edited by Gilligans Isle
added text
You have a pic of the green ones? There needs to be x4 valve seals in the kit. Maybe the green ones are the valve seals intended to be in the kit, and the brown one was an anomaly that made it’s way into your kit accidentally? — It’s still a valve seal, though, regardless.
Okay thanks guys. Mine is an 86 xr600r, I was thinking it went in the plunger system on the oil pump as that was the only part on the parts fiche that even looked remotely like this seal . :)
