"Carb screw boss cracked''
Use JB Weld "Steel Stik" then re-drill and tap for the bolt size. It will get you by. We did that on my buddies 04 Cummins exhaust manifold for his EGT probe. It sees way higher stresses and temperature swings than a carb, and it's still holding up strong. Don't torque the shite out of that little bolt either after. It will get you by.
ACV air control valve? is it on WR to keep it green for emissions ?
Do i really need to worry about it? in terms of performance
Motor is on a fresh top end new valves piston, rings and cylinder
"BTW Thanks for all the input"
Edited by olddude13
9 minutes ago, olddude13 said:
"I  scored the yz eBay carb"
I will swap over my jd kit, quick shot and see how it works if i doin't like it i will jb weld a threaded piece of aluminum to carb body plus silicone on cover
Obviously our advise was a waste of time - how much money did you waste ?   :D
