What to to do on 300 RR
Mark-us-B sceptical?
I'm basing my pricing on Les's high side estimate + $100-$150 for packaging and shipping..... I could and would justify the price if I hadn't seen the other system. No doubt it would far better than stock (which I like).
When I hear more about the inserts I'll pull the trigger.
My understanding from enduro spec is that the price includes rider specific tuning.
I did like Les, he has my business if I go that route.
I'm sure that if I had your years of experience I'd be done by now. I do appreciate the responses they are helpful.
I probably wouldn't even post my ignorance, except I think it helps other guys like me to see what's out there and hear feedback from a novice.
Spring is here and my bike looks like20180312_164909.jpg.29832b65c6bbb2f11f04b7e37016e0c6.jpg
Didn’t mean to sound overly skeptical, my bad!!
I grind and look for way to save 24/7 when it comes to my hobbies/toys (Dirt&Street Motorcycles/Drift&PowerBoats/Alfa-Spider/JeepRubicon/RAM-CTD/FlyFishing/Labradors/Hunting) etc. etc. etc.
So I’m constantly pinching coins and rubbing them together to squeeze a little extra out of each of them, lol!!!
Packaging is a game I play on using only UPS for my suspension, pre-package my stuff so it can be returned in all the same packaging.
Best of luck with your endeavors, seriously. When I started with that new clean-blank slate (2014 Beta 450RS-BYOB bike in 2015) it was daunting to get it correct for my needs, it took a couple of years.
Though even today I do look at CC-forks, as I sometimes tackle big rock gardens and other obstacles that the OC fork in general struggles with, I toss around the idea of just exchanging my Sachs OC’s for Sachs CC’s. But for me at least the Sachs OC forks perform great on 85-90% of the trails I hit.
Cheers!
M
  • Like 2
Cheers!
M
Add golf for some additional punishment.
  • Like 4
Posted (edited)
Question : do I need to remove the base valve and the cartridge to change the spring?
If not do I need to re-prime the cartridge? If I don't have to remove it?
Peace,
Edited by newk75
Peace,
Nope, super easy. Loosen the fork cap, pull up, seperate the cap from the damper rod and extract the spring.
Drilled a hole fractionally bigger than the fork tube into some black walnut I had laying around. I figure wood would be soft on the aluminum. Spilt one side so I could compress it. Works good, holds it very solid. Need to work on something besides 2x4 that's adjustable to hold the lower fork tube. 20180316_173250.jpg20180316_174342.jpg
Got springs installed. Need to set oil level. Saw in one video 130 mm is that standard or is there a chart?
  • Like 3
130 is stock setting, with springs removed.
Does larger spring use less oil, or is it insignificant? I went up two spring sizes.
nope, use the same oil height then tune to your liking from there.
i'm stealing that wood block tube holder idea! dig it.
Just crack the cap loose in your triples with the top loose, bottom tight.  If your not a woodworker,  rubber soft jaws just snug work fine with the bottom of the fork supported/elevated.  A very useful tool is an old triple or triples of the correct diameter(s).
