Hello, I'm having an issue putting my kicker assembly back together. A while ago I had the whole kick start apart and, when I put it together the the kicker would hit the peg every time I tried to start it. I was wondering if that is normal because it cracked my case and I had to weld it. My second question is if you have to rotate the return spring a whole 360° to set it? The marks that you have to line up have wore down and, the only mark left is on the ratchet.
