2005 WR250F Battery/Engine Issue
Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
Start with a service manual and a fully charged, good battery, then do the tests in the manual. Not knowing where in the world you are living, we have no idea what sort of conversion was done to make the bike road legal. My own WR has two power switches, one is the stock 'on' button and the other is on the bar switch. Both must be off or else parasitic draw will kill the battery.
A WR uses a DC CDI and if there is insufficient battery/DC power, the bike will not run. Causes can be a bad battery, bad ground or connection. Bad stator or broken wire. And fifty other possible problems.
