cant replace engine kill switch .
my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
plz Help :D
They can stick as you know.  No trick just make sure you grab each end and pull. Maybe some needle nose pliers? Twist the ends a bit as you pull.
Spray some penetrating oil or WD-40 in there if you need to.
Edited by HRC27
thank i will try :D . they have stock together like a one pice .
Make sure You undo the tab at the same time You pull..
undo the tab !? there is a tab which i press in. but what do you mean by undo the tab !?
