Is it ok to stwitch from normal non synthetic oil to synthetic ?
My guess is that this is left over from long ago when seals were not meant for synthetic oil. Today, as long as you drain first, I do not personally know of any issues this could cause.
FROM  THE FOLKS AT EXXON MOBIL
"In general, oils should be compatible with each other. It is not likely that you would form gel by mixing the two oils. However, we would not recommend mixing oils as a general practice because oils are complex mixtures of additives and base oils that can be destabilized. Also, why reduce the outstanding performance of Mobil 1™ synthetic motor oils by adding “regular oil”? Is it economics? You would be better to run all Mobil 1 and run it longer than mixing it with “regular oil.”"
If your oil is in the manufacturer recommended specs, use it and don't worry about what was used before.
You can switch back & forth anytime.
Thanks guys !
Thanks diver appreciate you always answering my questions promptly much appreciated!
I've done it and added non synthetic to synthetic to top off before. Never noticed any I'll effects as long as you change it when it should be changed.
Many synthetics are actually a conventional, mineral base oil that has been hydrocracked.  They are chemically the same as a conventional oil but they behave comparably to a fully synthetic oil.
Draining and filling with a different oil can't really be considered mixing in any case.  There will be a small amount of oil left in he engine but not enough to worry about.
Its a drz, you can run them on mud and piss for thousands of miles lol
While this may be tempting, it don't work. Guy in high school actually put Pepsi-Cola in the crank to lubricate his 1981 XR200. It didn't work well for him. My advice is to bulk up on 10W40 of any brand (and especially automotive oriented since it meets the API requirements!) when it's on sale. The DRZ don't care if it's synthetic, semi-synthetic, or conventional let alone brand.
Edited by shrubitup
While this may be tempting, it don't work. Guy in high school actually put Pepsi-Cola in the crank to lubricate his 1981 XR200. It didn't work well for him. My advice is to bulk up on 10W40 of any brand when it's on sale. The DRZ don't care if it's synthetic, semi-synthetic, or conventional let alone brand.
I poured water into a Honda 1.5 dx sohc motor and ran it wide open against the limiter for a full ten minutes, i got bored before it siezed.
What about Rotella
What about Rotella
This is right.  I occasionally rebuild 70s hondas, and do not like to use synthetic for that reason.  I don't trust 70s and even 80s seals to hold up to synthetic oil.  If you have a modern engine, you should be fine.  I prefer synthetic as it performs more consistently across a wide temp range, and can last a bit longer between oil changes.  For older Hondas I use Rotella.  Cheap stuff, more frequent oil changes.
You must have hated that Honda
Pretty much standard procedure for me. I like to make stuff fail. There is usually a bet and some alcohol involved.
Says a lot about the DRZ !...
Ooh, i don't treat MY stuff that way lol.
Ok when I make my way over to Oregon some day & bring a 'buddy bike' for Wayne, I'll be sure not to bring you one lol...J/K.
Get out here sooner than later man! Oregon is awesome to look at.
 Unless you're from Massachusetts
