Thinking (too much?) about jetting
Bgringo, 2 pieces of advice:
The first is this link to a Google Sheet with all kinds of jetting scenarios:
https://docs.google.com/spreadsheets/d/1HNSB3DrqJqHTInjVDKKS4HNSHZPbdK0ElbfNI5HxuZg/edit?hl=en#gid=1172546203
The second is just my experience with a JD Jet kit living in Boulder (5,500ft and typically riding up in the mountains around 9k).  I tried jetting for high altitude with a 145 main jet and red needle on second position from the top.  Riding at 5,500 I felt like the bike was running rather lean.  I adjusted to a 150 main and red needle on third position and now it runs great, at least at 5,500ft.  I did also install an MRD Z-Pro exhaust at the same time as my re-jet, so it's somewhat difficult to compare the two jetting postions.
Perhaps the only good thing about the Mikuni carburetor on our bikes is that it supposedly adjusts itself for altitude changes better than the FCR...
My previous thread on this topic is here:
Good luck.
I am running a 155 main,blue needle clip 3 and 25 pilot at 1753m above sea level with the JD kit,powerbomb header and fmf pipe with a foam filter-runs like a bat out of hell.These settings were according to James Dean by the way.
Thanks RockyMntnMike,
I did read your post about elevation jetting and the spreadsheet of data.  I'm reverse of most of the posts I read about it.  I'm already up high and am looking for the lazy way to change to a lower and then back to higher without having to swap the jets every other ride.  I'm just trying to find out if I go with a richer jetting and then dial off the fuel using the fuel screw will it work?  I haven't seen anything out there mentioning it, so I'm just going to do it and see what happens.
Won't have much effect except idle and a bit more.  I'd jet just a bit rich on the mj at 9k and move the clip around until I found an acceptable compromise for the elevation changes, if there is one.
Edited by npm
