Hi,
Thanks
Timo
Moving the E-clip up will lean the mixture - probably why its running rich
2.JPG.93ea767d4dea6e24f695529968ce146c.thumb.JPG.26c4660eba3db1907facf2ca40212f71.JPG
Hi Thanks For reply. I found if I moved it up one it just tended to splutter a bit at mid range from memory. I just want to put her back to stock, thanks for carbs diagram btw.
Anyone got info on the other questions?
142.5 is stock main in UK
2nd from top
Parts diagram above shows correct order
They run shite on std jetting. Mine woulnt even pull away without stalling even on choke in cold weather. The OE needle is too fat on the initial parrallel section causing it to way too lean to the point it dies under load.
Fit a Dynojet kit and you will be happy. Had mine in for 13yrs and it runs good
Hi Graham,
I looked through the PO parts that came with the Sigma6 kit and the original jet that was fitted was a 134 (clearly written on the main jet)? I wonder if it was even from this bike?!
I'll fit a 142.5 Main jet for now with the clip 2nd from top, mix screw 3 turns out with a stock exhaust and stock airbox I've just bought. I'll see how I get on. If not I'll do as you suggest and get a Dynojet kit. I don't suppose you remember what jets and settings you used, it was 13 years ago....did you keep everything else stock or do the usual mods?
Thanks
3 x 3
140 Main
22.5 Std pilot jet (even though on TT it suggests you go up to 25 but USA bike have a different pilot air jet)
DJ needle with clip 2nd from top
DJ slide spring
Fuel screw 2 turns out
Float height needed setting to the high end of its spec (ie lowest fuel level) @14mm to avoid a bog/hiccup when cracking the throttle open from closed ie on the overrun (this was the only way to solve it as I couldn't tune it out with jetting/clip position on the needle without it affecting something else.
Std UK S Model exhaust unmodified
details in here
Edited by GuyGraham
The sigma6 jet kit fitted may well be a DynoJet kit in a different box
I bought mine as a FMF Jet kit, but the instructions inside had DynoJet on them confirming it was the same kit just in a different box
Edited by GuyGraham
