What's in your clutch basket?
Pretty sure I smoked my clutch over the weekend, or maybe it was just fading a bit because it was hot. Either way, I need a better clutch.
1) What aftermarket friction discs are you running?
2) How do you like them?
3) Would you run them again?
4) If not, what would you try next?
TIA! :cheers:
I have had and seen otherwise stack height issues with the aftermarket clutch is on this bike the stock this works so well with motors of all build I see no reason to use other than the stock Drive and driven plates
I do use some slightly heavier springs
The stock plates even work well in the slipper clutch And the few installs of a recluse I’m done
Take a good look at the pressure plate as well if it is worn down replace it affects both stack height and contact with the Ater friction plate
Posted (edited)
9 minutes ago, Erik Marquez said:
I have had and seen otherwise stack height issues with the aftermarket clutch is on this bike the stock this works so well with motors of all build I see no reason to use other than the stock Drive and driven plates.
Quote
1) What aftermarket friction discs did you try?
Maybe it was just overheated, but like I said, it is either toast or not handling heat well. I have been using it a LOT for single track and muddy hill climbs, so I'm not too surprised that it is no longer top notch.
Does Suzuki use kevlar on the stock friction plates? Most people with built Harleys tend to run Barnett clutches, which are kevlar.
Maybe I am one of those cases where a Recluse would give me much longer clutch life?
Edited by Bermudacat
Had a Rekluse on the Orange bike and liked it aLOT! Only drawback was not being able to bump start it down a hill. Has something to do with the discs slipping and not grabbing. Other than that, I loved it.
I will check into that, thanks!
D100 was brutally  muddy! Glad I opted for some fresh knobs. :smirk:
  • Like 4
TIA! :cheers:
I like OEM.
Ran a Moose before (rebranded DP) no problems.
  • Like 2
Gonna give the Barnett a try.
Looked at a couple BETA's today; time to close the DRZ mod spigot and start saving up for a 21st Century bike. :ride:
  • Like 6
Rekluse torq drive core manual. Flat out grabs like nobody's business and feels like a h.p. upgrade. Doesn't fade or slip and has stainless clips over the basket that can be replaced for $15. No more basket notching. The only downside is the crankcase cover doesn't indicate whether it's the gay or straight version of Rekluse.
  • Like 3
Well, I better be open minded if I decide to date one. Pretty sure the DRZ Recluse is nowhere near that trick, so perhaps it's just a eunuch.
The only thing the RE doesn't have is guards, so maybe the Recluse would be a good first mod. ;)
  • Like 4
I really don't know the make up of the friction material. Id guess if it was Kevlar, the marketing department would make a big deal of it, so Id guess no its not.
I think an Auto clutch is reasonably hard on clutch disks.. more or less abusive then how you use your clutch now is just dependent on how you use the clutch.
I know some riders that cant get a season out of a clutch.  I have a 2003 DRZ with the original clutch and put thousands of single track miles, hill climbs, but runs, even a few races from 2 hour scramble to two 24 hour GP's
But my RM250 clutches last only a few seasons
I will keep that in mind, thanks. :thumbsup:
59 minutes ago, braapktmbraap said:
Has Antoine here tried wisco?
Just purchased the last four Barnett P/N 301-35-10012 for the project.
A total of eight are necessary, one 301-35-10013 and seven 301-35-10012.
  • Like 2
Ok, breaks down like this..................................
Barnett drive plates (kevlar) .119 thick
Plates in my bike .117 thick. Well within the .102 limit.
Driven plates (steel) look great and are not warped using a granite counter top as a reference.
Spring height 1.922, outside of the minimum 1.96 specified in the manual.
Can you overheat your springs and make them sag? Yes!
So Race Fans, you've seen it here, in the TT Zone! :smirk:
Won't be needing new drive plates just yet.
  • Like 5
That was similar to my experience with the DRZ clutch,Plenty strong and meaty but the springs get weak after a while and all I did was put in a new set of oem springs and the clutch was great again.
I was out riding today and my clutch started slipping. Bummer.... I ordered a clutch kit but cancelled when I saw this thread and did some more research. Seems like the fibers and plates are hard to wear out and I don't ride all that much so I'm looking into other causes. I found my Hymec Hydraulic clutch is a little bit installed wrong and putting a bit of preload on the clutch. So I made some mods to fix this.
If it still slips are there good aftermarket springs to consider? I see an EBC spring kit on amazon for 10 bucks...
My Hymec was putting a little preload on the actuator arm... Something to check for to everyone who wants one or has installed one. I got out the angle grinder and shaved off 3/16ths of an inch from the slave cylinder perch/ cable perch to give the system a little more slack. Will find out if it still slips next time I beat on it!
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
