Top Gear Wide Open Throttle Time Limit
Back in 1986 I quickly learned the importance of jetting as I seized a practically new Honda CR125R
in less than 10 seconds holding it WOT down a gravel road in 5th gear.
You can't blame insufficient oil as 20:1 was the recommended ratio back then!
A super rich main jet is the answer if you want to turn an MX race bike into a road racer but,
be prepared for it to be too rich everywhere else (trail & track) and, any engine braking should be avoided.
For relatively short MX courses, a leaner main jet (stock) usually promotes quicker revving and good overrev
but is not sufficient to cool the internals for sustained WOT riding.
Always a favorite example to show kids :
Edited by mlatour
  • Like 4
Outboard boat motors run WOT all the time. 2 stroke bikes can too. But as mentioned you’ll want a big main jet and an oily mixture. 30:1 or less. My old Merc 90 “tower of power” called for 20:1 so that’s an indicator.
High RPM doesn’t allow time for the oil to drop out of the fuel mixture as well to protect parts so you need more oil.
Even with a very large main, you can get a bike to run reasonably well below WFO if you tune your needle and pilot accordingly. Not great, but rideable.
  • Like 3
:thumbsup:
Chain saws, yard equipment, and even them gas scooters, all run WOT for a long time @ 50:1. Boat engines are cooled by the water they are in. So, has to do with cooling, jetting, and a few other factors. WOT on a dirt bike sitting still will kill it, no fan, minimal cooling, and improper jetting main factors.
Releasing the throttle and starving it on the deceleration is just another factor.
  • Like 2
The problem is that if you jet your bike for wide-open roads, it's not going to run very well on the trail or track.  An old-timer trick for long road runs is to just hit your kill button periodically for a second or two while holding the throttle WIDE-OPEN.  As soon as you release the button, the motor will restart.  The wide-open throttle will allow a large volume of fuel mix to lube and cool the engine.
  • Like 3
Genius, lol.
