Cam Bearings help
Hi all-
Bought a 84 xr250 with a blown head gasket cheap.  Have fixed the head, but during fix noticed the camshaft bearings are worn pretty bad.  No longer OEM available, none on ebay.  Any aftermarket options?  Thanks in advance.
Eric
6003 & 6003Z are the bearings youre after
Buy quality bearings tho
You should have a local bearing supply house. Take them your old bearings and have them match them.
Make sure they are are not sealed
Thanks all-unfortunately the local bearing house is 2 hours away--hoping for an online purchase.  Good quality, unnsealed--check.
Thanks again--Boondocks
