Yz85 idles normally then idles low
I have a 2002 yz85 and when you start it up, it will idle really low then once you rev it up a little, it will start to idle normally but then after a couple seconds it just drops back down to a really low idle like its about to stall out. What could be causing this? After doing some research it sounds like it might be a crank seal leak, but i really hope not. Could it be anything else causing this? And if it is a crank seal leak, would it require splitting cases to replace? I also just cleaned out the carb and put fresh 32:1 in it.
Edited by Koray
