Hey guys. I am totally new to this forum and to the world of motorcycles (well I've ridden them but never worked on them). I have seen a few similar problems in other threads however I am what you could call mechanical un-inclined. So basically I could understand most of the reply's. So if anyone has a ultra baby step solution to this problem I would be greatly appreciative.
Okay so here's the deal. I just bought (yesterday) a 1997 Suzuki DR200 that I planned on using as a get around town and exploring bike as a pretty beginner rider. When I bought it it ran great. When I got it home yesterday it ran just fine. When I tried to start it this morning it wouldn't go. It was turning over but not firing. So I pushed it down the street to a friends house who is pretty good with bikes. I live on a hill so on the way down I was able to bump start it and it ran perfect until I got to his driveway and stopped then it stalled.
So we took the Carb off and cleaned the jets and put it back on and it started right up. I took if down the road and back and noticed it idled to low so it would stall if you didn't give it throttle. We turned the idle up but then it was so high that it would basically keep going in second gear with no throttle added. So we turned it back down but once again it died. This time it would not start and we killed the battery. We tried several times to bump start it with no positive results. So we pushed it up the hill and on the fourth try it worked and proceeded to bump start every time after than.
But the problem still remained. We drove around and got the battery back to where we could start it with the electric start but it still wouldn't idle. And now it seems like it takes forever to come down to idle, like I will release the throttle and it will keep on going.
I am at a complete loss as I have no clue how to work on bikes. Heck I don't even know what half the parts are used for or called when I see them in other posts.
Basically can someone explain this so an idiot like me can understand?
Also I see that there is a place labeled kick starter but no kick starter. That would sure be nice to have. It there any way that one can be added?
Really any help or advice would be greatly appreciated. Thanks a ton.
if it's not the carb it's the valves. it could also be an intake leak. if the air filter is bad or not on all the way it could cause a crazy idle like that. my dr 350 would idle crazy because there was a port in the carb that was letting air in. I plugged it and it was all good after that. I'd recommend spraying some wd40 around the carb and see if it bring the idle up. wd is flammable and if there's a leak it will make your idle go up
Update: So after work today I tried to start it and it started right up and idled fine and I even took it down the road for a spin. Let it sit for several hours and again it started right up. One thing I forgot to mention was that I found gas in the air filter after we had done the carb cleaning and it had died. We dried it out and kept running it with the same results. I don't know maybe the cleaning did the trick I just needed to let it sit for a little while and I rushed it. I also don't know when the gas got there. If it was old or if it was from when I took the carb out.
I am going to try that trick with the wd40 tomorrow. I also plan on buying a carb rebuild kit and going through and replacing a bunch of the internals and giving it a more in depth cleaning but for now it seems to be working again just fine.
Thanks for the input  :)
Gas in the airbox is the tell tale sign of a failing petcock. That can have an affect on starting and getting it consistent bc some times it will be rich from sucking in too much fuel other times it may run perfect. I replaced mine with a non vacuum operated one and it works great now, just turn it to off when not in use like any dirtbike. Another thing to check related to that is check you dont have gas in the crankcase as the airbox has a tube that connects the two. At one point I had close to a gallon of gas between the crank and airbox
I will go and check that right now as after a few days of starting right up it is back to turning over but not starting with the electric start. I got a batter tender and put it on it so I dont have to worry about a dead battery but I still cant get it going :(
As I got my DR200SE in 2011, it wouldn’t idle but died. On giving it gas it would run. The problem was in the idling jet which was closed by deposits as the bike had sat unused for a long time. After cleaning the idling jet I have not had this problem again.
I bought a whole carb rebuild kit for it. Been really busy and haven't gotten it in yet but hope to tomorrow. Fingers crossed it works. All new jets and gaskets.
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By Wombat221
      Hey everyone, i was just wondering how do you adjust the accelerator pump timing on the FCR Slant Carbys, Thanks
    • By Dean.b
      Long story short I bought this 2011 WR300. The thing is mint, looks brand spanking new. The thing ran like a top, but only had one problem, a low idle. I was to lazy to fix it and just dealt with the fact that I always needed to keep a little bit on the throttle. My third ride on it, I took it to the florence dunes and the top end burnt up. I have just finished fixing it and all I need to do is break it in. I need to adjust the idle first though, and don't know if I'll have the idle too high until it starts. I don't want to hurt the motor on a fresh rebuild and want some opinions on what to do. Do you think it will be fine? How many turns out should I set the carb just to be safe?
      Any response helps
      -Dean
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Collin Johnson
      My throttle cable broke right close where it connects to the lever. I ordered one of of Ebay that was the right length and looked similar. When I got it in the mail and compared it to the old one, the "bolt" that screws in to the housing is bigger then the old one so I can't screw it in there. Can someone tell me how I can make it work? I'm including pictures.
