Antigravity Batteries Product Giveaways - LAST NIGHT TO ENTER! Read more... ×
05 YFZ450 Charging issues
*NOTICE* Long story, sorry in advance.
I have an 05 yfz450se. I wheelied over and broke my grab bar. Didn't have anywhere to mount my brake light so i just unplugged it and rode on. 10 minutes later i heard a pop and lost all power. Battery was very hot and swelling. So i bought a new battery (amazon special) to troubleshoot, it arrived charged and in good condition. Hooked it up put DMM on battery, fired right up. I noticed that it was charging but slowly climbing at a constant rate, so i shut it off around 14.5v Let it sit and tried again, again it done same thing. So i bought a Ricks electric motorsports updated stator/rec combo and installed properly. Put battery in, started and it read about 12.8v at idle, blipped the throttle couple times and it jumped up to 13.4 and went back to 12.8 at idle. Figured everything was ok. so I pit seat back on and putted down the lot for about 45 seconds and lost all power. Hooked DMM up to battery installed in quad and it read 0.0v, unhooked it and it read 1.9v so i hooked it up again and read .09v. Took it home, next day I brought battery inside and it read 5v. Hooked 2 chargers up to it and neither would charge. Funny thing though is when the battery isn't hooked up to anything it reads 5v, but soon as i hook a charged up to it or put it in the quad it reads .09v.
Pretty sure battery is junk but am wondering if the charging system fried it. I emailed rick's and got specs for troubleshooting but they just gave me numbers. Not which wires to test for what numbers.... any help would be appreciated.
Thanks in advance,
Mike
I'm pretty sure my 05 manual says it should be 14 v so its possible your still not charging properly and that's why the battery is dead after riding. Still sounds like your battery is junk though. Ill check my manual tomorrow to try and find what wires you need to test.
Battery was junk. Lasted 45 seconds lol. New battery and it runs and charges just fine.
Thanks for the help,
Mike
  • Similar Content
    • By Mmanos3
      Ok i have this starting issues with my  04 yfz 450 like many others have. i have a high compression piston and its jetted with a hmf pipe. I have replaced the battery twice with higher cranking batterys, replaced the starter, had the valves shimmed, had the carb rebuilt, and The spark plug is new and gives good spark. I also run the quad with my headlights on whenever i bump start it. The issue im having is whenever i completely charge it up and take it out it will fire right up on the first click of the starter but if i shut it off it will not start up again without bump starting it. It sounds like there isn't enough juice pushing the motor over and sounds like the battery is dying but if i put it on the quick charger it says i have a high percentage left on my battery.
      I was thinking stator, cdi box, or a relay please help its killing my wallet and motivation lol
    • By worldwager
      i have a 2012 yfz 450 stock. today i bought a powercore 4 full exhaust do i need a programmer to get the power from the exhaust or can i run without?????????
    • By Randy Sorensen
      Hey guys, I bought an 07 Yamaha yfz450 off Craigslist with the bottom end seized. I am rebuilding this using the big bore kit, making it 500 cc. I have full exhaust, open lid, and I'm at 835 ft above sea level. What do I need to get for jetting on the carb? The carb is all stock.
    • By Randy Sorensen
      I am currently rebuilding my yfz450. I decided to buy the hot rods 500cc stroker kit. I was wondering what jets I need to run. It has full fmf exhaust, uni filter, riding at 800ft. Above sea level. I currently have a ncqv needle on hand along with 170 through 180 main jets, and 45 through 55 slow jets. I don't want to do the trial and error thing for two weeks, what should I start with?
