ktm-don Posted May 19, 2018 I need to replace the plug on the wiring harness that connects to the tank of a YZ450F. I've got the tools to crimp terminals, so installing a spare connector would be easy. However, I can't find it as a separate part, and don't want to buy an entire harness. Any suggestions for finding this part? KTM publishes a list of spare connectors for their bikes, but I could not find anything like this for the Yamaha. Thanks in advance! Share this post Link to post Share on other sites
S.O.A.N.Z Posted May 20, 2018 maybe replace both male & female connectors at the same time https://www.economycycle.com/shop/bullet-connectors-wire-electrical/electrical-connector-blocks-sold-each/ Share this post Link to post Share on other sites
ktm-don Posted May 21, 2018 The mating connector is part of the fuel pump assembly, so replacing both is not an option. So far I've not found a source for replacement other than a full wiring harness, which is overkill for one simple connector. It may be a Yamaha specific part, or a more readily available commercial item, I'm not sure. Share this post Link to post Share on other sites
edv2009 Posted January 8, 2020 I’m sure you can find anything here. http://www.cycleterminal.com/motorcycle-connectors.html Share this post Link to post Share on other sites
cowboyona426 Posted January 8, 2020 Corsa Technic is another great source for all things electrical connector- www.corsa-technic.com/ Share this post Link to post Share on other sites
yz250f 78 Posted January 8, 2020 On 5/19/2018 at 6:45 PM, ktm-don said: I need to replace the plug on the wiring harness that connects to the tank of a YZ450F. I've got the tools to crimp terminals, so installing a spare connector would be easy. However, I can't find it as a separate part, and don't want to buy an entire harness. Any suggestions for finding this part? KTM publishes a list of spare connectors for their bikes, but I could not find anything like this for the Yamaha. Thanks in advance! Post a pic Share this post Link to post Share on other sites
wetneck Posted January 8, 2020 (edited) Lookup. pj rega on fb Probably has a used harness You could also just get the spade connectors, shrink wrap them , zip tie and ride off into the sunset Edited January 8, 2020 by wetneck Share this post Link to post Share on other sites
ktm-don Posted January 8, 2020 Turns out that the harness had a weird internal short, had to untape it to find the issue. So the connector was not the problem, and some solder and shrink tube got things right again. Thanks for those that offered suggestions, I appreciate it! Share this post Link to post Share on other sites
Clint Hemsworth Posted January 9, 2020 Does it have the three tube shape plug with two wires going to it? Share this post Link to post Share on other sites
