99 cr250 power valve not workimg
Adjusted the power valve on my 99 cr250 and not the power valve won't move at all
I took the pin out of the top to clean the linkage up a little bit could the drive shaft have disconnected from the pinion shaft?
Generally what happens is when the cylinder is put back on the cases no one pays attention and the crow’s foot on the drive shaft gets smashed by the pin on the pinion shaft.
Ok found the problem
Someone wasn't paying attention when they connected the pinion shaft to the governor the pinion shaft was one tooth to far clockwise looking down onto the motor causing the drive shaft not to be able to move as far therefore not opening the powervalve
I'll post a video as soon as I figure out how...
You are luck then, most of the time the shaft gets smashed and broken and it’s not cheap to replace or easy to find anymore. Glad you got it figured out, once you get the shafts working together the manual should walk you through how to set and adjust it. If you have anymore questions let us know.
Here's the video
