Still having white smoke after piston and gaskets replaced!!! HELP
Posted (edited)
I created a thread a couple weeks ago about having white smoke pouring out of my exhaust after a hard ride and i was told to replace my base gasket and head O rings. While i was in there doing that I threw in a new top end as well. Started the bike for the first time today to break it in and after about 10 minutes of idling i gave her some revs and still have heavy white smoke pouring out under throttle. Any other suggestions? Maybe water pump related?
Bike is an 06 yz125
Edited by yamagod95
  • Like 2
Have you tested if your head is warped?
If waterpump related the water has to cross the oil barrier first and pass another seal.
No i have not. But i think the head is fine it looked perfect and the piston moved smoothly
I can't see a warped head by eye. I need a window to make it visible.
Recognizing a warped head by eye is about the same as testing your compression with your thump.
Edited by arnego2
  • Like 4
Recognicing a warped head by eye is about the same as testing your compression with your thump.
Gotcha, i just don't think its that. But i could be wrong, hopefully not though
Easy to repair, some sandpaper and a straight glass aka window and after 15 min it should be good.
  • Like 2
I briefly sanded it on a block before i reinstalled it but maybe i didnt enough
Do you see any wash marks on your piston top?  Antifeeze/coolant will steam clean it. Don't go crazy on that head and make sure you are using a plate of glass and not a sanding block.  Are you getting any severe bubbling in the radiator when you run it (cool of course and with the cap off)?.  Check the seal on the water pump.. Are the o-ring seats clean and free of any type of corrosion?  Just a few things to look at.
  • Like 2
I installed a brand new piston last night. And while i was breaking the top end i let the bike idle for about 10 minutes, then as soon as i gave it a few revs instantly massive white smoke. I did notice a tiny tiny bit of over flow from the radiators. But i was just thinking that could've been just because i just refilled the coolant after the rebuild.
What’s your water pump look like? Pretty sure the shafts can wear out and allow coolant by.
If nothing else, buy a new gasket kit for the water pump and reseal it. Gaskets are cheap.
Just now, Studhaeuser said:
You sure its coolant? Did you pressure test it?
No im not 100 percent sure its coolant. People have told me white smoke is from coolant so im thinking it could be. Which is why i replaced the base gasket and head O rings. But still same problem
Havnt checked my water pump yet. Definitely need too
White smoke can also be trans fluid. Did you pressure test it?
  • Like 2
I dont have a pressure tester unfortunately so no.
I'd start there. Keep an eye on coolant and trans oil levels. A bad water pump seal wont let coolant into the combustion chamber. Theres also the possibility of some oil buildup from trail riding burning off when everything gets hot. Burning coolant smell is pretty distinct but Im assuming youre not familiar.
If its coolant doesn't that mean that it's somehow getting into the combustion chamber? The burning smell I get smells like the bike is over heating so to speak. Also how do i check trans oil level? By just removing the bolt?
Did you clean out the power valve cavity?
what brand and mix ratio oil do you use?
is your silencer packing saturated with oil?
Is your jetting stock or rich?
Does the engine idle clean after the top end?
a little white oil smoke happens but a ton of smoke is a problem
Is there a lot of “spooge” running out of the silencer?
Run it with the rad cap off and see if there’s any difference
wont pressure up that way..
 Cleaned the power valves thoroughly
I run 36:1 belray h1r
Silencer is new 3 rides on it
jetting is stock
Engine was idling very high at first start after new top end but eventually settled down.
No spooge at all
If that helps. What will that tell me. Somethings telling me its crank seals.
