I have a 2012 yfz 450 and when I go to start it the solenoid just clicks after I've just charged the battery. So 5 minutes later I tried putting it back on the charger and it started right up while on the charger, then I took it off the charger and it cranked slow once then went back to clicking. It's a brand new battery and I tested it with a multimeter and it reads 12 volts so I don't know what's going on. PLEASE HELP!
12 volts is too low, it should be 12.8
When you try and start it, the voltage at the battery should not drop below 12.5 I bet the battery is bad and you should also check the machines charging system.
