Steering lock and wiring
Has anyone rerouted this wiring harness around the steering lock? If so let's see a picture of how you did it. 2018 300RR.
What I did was to remove the harness from the white cable clamp then reinstall the cable clamp and use a tie wrap to attaché the harness to the top of the cable clamp which holds it away from the steering lock. It works but I am looking for a permanent solution. I will post a photo later if you like.
So, I removed the head light,unplugged the wiring and did some rerouting. Came up with this,less kinking of the wiring harness when you turn the bars.image.jpeg.ef8e51339369ff2301ce21cb0ab2e308.jpeg
