Rad Fan...can you test it?
Good Day all,
2014 DRz400s.
I have never heard or seen the Rad Fan "cut in" or "be on".
I know can put power directly to it to test the fan motor etc....but is there a way to test it to see if it works as it should thermostat wise?
Cheers
Macdon221
let it idle about 15-20 minutes in the garage if it goes over 20 mins it probably isnt working ... the danger here is walking away while your waiting and forgetting its running, dont do that .. bad things might happen that will cost you money lol ...
  • Like 2
I believe with my aftermarket dash, my fan doesn't come on till it gets to about 104c or about 218f. It's got to get really hot.
5 hours ago, Chargerman said:
Good Day all,
2014 DRz400s.
Cheers
Macdon221
Takes a LOT of heat before the fan comes on, so I understand why you're wondering if it works. The only time mine comes on is if I'm sitting in traffic, riding really tight slow stuff, just barely above idle OR....when I'm ripping up a mountain at full throttle for fairly extended periods....on a warm day.
Yours likely works just fine, methinks.
  • Like 3
If the system is working, the fan should come on when the coolant temp reaches 205deg F, fan will shut off at 196 deg F
205deg is not all that hot, and will happen at idle sitting still on a warm day.
