SoCalXR600Rmonkey Posted June 15, 2018 well hello all, seems like forever since I posted last. and it has been five years. wow! at least I never quit reading all the posts. as I fix OP's XR's (doing lots of wiring esp) I have noticed that almost all the bikes have an original Honda harness with the dual sport wiring laid over it. most dual sport kits supply new leads for the positive side of new lights etc but most often the add on stuff tags into the Honda GREEN ground wire. the Honda harness had little to control so there is one small (I am hard pressed to call it 18ga) GREEN ground wire running end to end in the harness with a branch off it to frame ground at the coil mount. darn near every harness I look at has a pretty sad looking "branch" wire. that is, the wire is all discolored and brittle from being overloaded. so my thought on this is to remember to inspect that wire when you find yourself having electrical issues... it may not be the cause of your problem but that's a perfect time to check it out and upgrade it. I cut the old wire out any time I remove a tank. feel free to get proactive. have a dandy! neil 3 Share this post Link to post Share on other sites
