74 Yamaha gtmx a 80 (gt80)
I’ve realized that my 2 oil seals for the crank are leaking as the left one is causing any adjustments to the carb to be useless and the right side I know has a leak because it’s a little too smokey.
I’ve taken both sides off and can’t find any techniques or solutions for taking the fly wheel off and the bolt for the right side crank. I have added my attachments to help make sense of this description.
Does anyone know if these nuts are left or right hand threads that would help a lot too.
There should be enough thread showing on each for you to chase them with a pick and determine right or left hand thread.
The inside of the flywheel for the puller is left hand for sure .
You better pop that clutch basket back on and jam a piece of aluminum in between the primary gears before you hit it with that impact.
