Yz250f carb bowls
Hey guys ive got ayz250f 2008 with keihin flat cr standard carb but the previous owner over tightened the drain screw and buggered the casing smashed the hole bigger so now im trying to find just the bowl to replace it but they ate like rocking horse sh$t ive seen a couple on ebay but they are off wr or crf s  are they interchangable they look the same can some one please tell me what ones are the same and where i can get one kind regards scott auckland new zealand
what size carb is that - 41mm ?
i think its 37mm
Edited by S.O.A.N.Z
  • Like 2
The opening on the side that goes to head is 37mm lads so have you got a bowl cheers scott
1 hour ago, Tat2dpom said:
Yeah i think i did already waiting on reply thanks
The drain screw or the 17mm hex plug? If the screw Id just JB weld it and leave it. I never used the screw anyway just the plug as the screw does not drain any water collected at the bottom in the plug.
Nah its the 6 mm drain screw mate i tried jb weld already it just leaked
Whats the diff between power bowl and powerbowl 2 ? Any thoughts before i buy one ?
I have a FCR 39mm bowl in the shed, should be the same - maybe someone can confirm from TT? Send me a PM with contact details and I will send you a pix mate.
I think they all the same does it have 6 mm drain screw in the bottom as well as the big hex one
How much ya want for it mines 2008
