Engine Stalling when Clutch Pulled In
Recently picked up an ‘03 450 sxf and took it up to the trails without any issues. However recently I rejetted the carb and since then the bike stalls out when I pull the clutch in fully. I’ve adjusted the clutch cable and that didn’t seem to fix it and also reinstalled the original jet. The bike also feels like the engine is braking when no throttle is applied even in higher gears. Any help would be greatly appreciated!
heavier flywheel will help
i had the exact same bike - used to stall like yours - then threw the heavier flywheel in - didnt stall after that
