Vinny's Build
Weeks back i blew the motor on my 650l. Decided to do a few upgrades while the motor was out
So far...
Installing some new plastics, plan on doing USD forks, and street rims.  A fellow member said he was very pleased with the dirtbike africa head pipe. Its a lot larger in diameter than stock as well. I plan on matting that to a DG muffler that i have.
HEAD:
-ported head
-new OEM valves
-springs mad by webcam
-Stage 2 Webcam
-Hardened cam lobes and hardened rocker arms
BOTTOM:
-Je 10:5:1 piston
-Slightly over sized to a 101mm
CARBURETOR:
-MIKUNI TM40
Heres the bike as it sits right now
  • Like 3
17 hours ago, Hollerhead said:
I'm always interested to know more when folks port heads.  Was yours flow tested before and after?  Any before and after pics? New seats and guides?
The metal inside is very rough. Was not flow tested. Will post before and after pics when finished
valve guides and seats were in good condition. Not installing larger valves either. Cleaning the surface that air flows through and sharping some edges. Nothing crazy. The surfaces are rough and gritty. air will flow easier when finished
Edited by Scaffold29
2 hours ago, Vinnym said:
Thumpnred i will look into the FCR carb. I like the mikuni because it seemed like a nice kit that came with everything you needed.
The FCR does involve a bit more tinkering to get it to work, but the job is pretty well scripted out. You can buy a ready to run FCR, but they are pricey. The less expensive way to go is to find an FCR off of a CRF 250 or 450. A NOSS adapter and some jets and a needle gets it up and running. If you can find a used FCR with an extended pilot screw and an adjustable leak jet, all the better.
Be gentle.  Results are sometimes surprising (disappointing).
Smoother surfaces are not necessarily the key to a good performing head.  A proper shape is great, and can be very beneficial, but without maintaining atomization through "good" turbulence you can end up with stale air and big ol' drops of gasoline in there and an air fuel mix that will cause you nothing but heartache when trying to tune.  Without a seat change, and the blending of them, any gains from port work can be completely lost.
Porting always sounds good in conversation but it is a science and requires some pretty fancy equipment to actually know if what's being done is helping or hurting.
Edited by Hollerhead
  • Like 4
  • Helpful 1
So what would you recommend doing while this is being done?
I'll put it this way.  I've never read of anyone being disappointed with one of these motors using a stock head with a similar set of guts that you list for your build.
In the past few years of riding and rebuilding these I've never read of anyone that worked on these heads with documented results.  I'm fairly new to these but have found that there doesn't seem to be many folks that work on these heads enough to have developed a proven method to improve them.  There are some great parts changers around but none I've read about that truly know how to gain performance beyond the bolt-on parts.
There is no doubt more can be gained from proper head work but finding the person to properly do the job is difficult.  Really experienced guys will work a little, flow it a few times to see the results, work a little more, etc. It's very common for even the experienced guys to make cuts that make things worse.   The flowbench is the only tool that will tell them whether what they are doing is helping or hurting.  Valve unshrouding, keeping the air "stuck to the port wall", and all kinds of other tricks seem be the normal on other heads and should probably be considered on these as well.
  • 1 month later...
