kwajesjakie66 Posted July 11, 2018 Hi, Recently the piston of my KLX450r cracked, it was still in one piece, but a large crack was across the piston which caused a complete loss of compression. I always thought that it would last minimal a 100hrs. Luckily no further damage, I replaced it with a forged WISECO piston, and ON THE PIPE! again. My question is, who has experienced this also at these running hrs. I ride 90% motocross with it, run a 2014 KX450F exhaust. Opened up the air box to the max, cut away the top, drilled holes to the side and rear, run a 170 main jet, and maintain and treat the bike well. Regards, Jan Share this post Link to post Share on other sites
Zinergy Posted July 11, 2018 (edited) Regardless of a position crack or just being worn I have known of a few 450s to make the 100hr mark. My 07 crf450r for example. Neither the timing chain nor the rings made it to 80hrs. That is an impressive crack though Edited July 11, 2018 by Zinergy Share this post Link to post Share on other sites
crazyal426 Posted July 12, 2018 Wow, mine made it waaaaaaay more than 100hrs. At least you know what the inside of your engine looks like now. Share this post Link to post Share on other sites
kwajesjakie66 Posted July 13, 2018 Lol, I wasn't curious to the inside at all, but while I hat it apart I took the valves out to check them: still 100%. Even the valve clearance was just as it was when the Kawa left Japan I changed the timing chain for a new one, and will change the piston the next time after 50hrs. My Kawasaki dealer also advises a 50hr interval. Cheers, ON THE PIPE!! Share this post Link to post Share on other sites
payloan My Rides (3) Posted August 28, 2018 Wow. I dont know how many hours are on my bike , But i have over 5000 miles on the original engine. I bought it new in 08 and it has never been apart. Runs great no compression loss. I have never seen a piston crack down the center like that. Share this post Link to post Share on other sites
kxlubber Posted August 28, 2018 What year bike is this? Is this possibility why they updated to a boxed bridge piston in 2010? Share this post Link to post Share on other sites
kwajesjakie66 Posted November 9, 2018 The bike is a 2008 model, I bought it new in 2014. Did not know there had been an update on the piston, but now I have a WISECO piston in, so everything is safe. It had been left sitting in a corner of the warehouse for 6 years, with zero hours on it. The dealer totally forgot he had it in stock! the bike was covered with junk. Share this post Link to post Share on other sites
F1Jim64 Posted November 9, 2018 The bike is a 2008 model, I bought it new in 2014. Did not know there had been an update on the piston, but now I have a WISECO piston in, so everything is safe. It had been left sitting in a corner of the warehouse for 6 years, with zero hours on it. The dealer totally forgot he had it in stock! the bike was covered with junk.Would guess lean if there’s a reason beyond just a bad piston forging. Bandsaw it open and look for a flaw. What’s the plug look like? Share this post Link to post Share on other sites
kxlubber Posted November 9, 2018 The bike is a 2008 model, I bought it new in 2014. Did not know there had been an update on the piston, but now I have a WISECO piston in, so everything is safe. It had been left sitting in a corner of the warehouse for 6 years, with zero hours on it. The dealer totally forgot he had it in stock! the bike was covered with junk.The KXF has an update on the pistons from 09 to 10 with some reinforcements, over in the Kx450f forum they are claiming 300+ hours of harescrambles/ practice on a piston. Bad Piston or like others have said Lean Share this post Link to post Share on other sites
kwajesjakie66 Posted November 10, 2018 I run a170 main jet and have the airbox opened to the max, cut the top of and drilled large holes in the side and back. Also run a 2014 kxf exhaust. It probably could have run lean because I was railing berms at a deep sand motocross track with WOT in third gear all the time. Even a Kawasaki cant stand this abuse I guess Share this post Link to post Share on other sites
kxlubber Posted November 29, 2018 I run a170 main jet and have the airbox opened to the max, cut the top of and drilled large holes in the side and back. Also run a 2014 kxf exhaust. It probably could have run lean because I was railing berms at a deep sand motocross track with WOT in third gear all the time. Even a Kawasaki cant stand this abuse I guess What needle are you running? Share this post Link to post Share on other sites
kwajesjakie66 Posted January 1 sorry for the late replay, A happy new year. I run the standard needle with the clip 3rd position from top. Do you recommend some other typ of needle? Share this post Link to post Share on other sites
kxlubber Posted January 2 sorry for the late replay, A happy new year. I run the standard needle with the clip 3rd position from top. Do you recommend some other typ of needle? My stock needle wasn’t adjustable. I recently did the NCVR for a ride and that was too Rich for 7500ft, now I’ve got a NCVS in there but winter interrupted my testing. Share this post Link to post Share on other sites
