Daniel627
1990 XR200R CDI question
5 posts in this topic
Posted (edited)
I came across this post earlier while trying to find something else, but it made me think about my bike, and think it very well could be my problem.
In this post, Chuck states to NOT use the CDI box from an '85 4valve motor on a 2valve motor.
When I got my '90 XR200R I had the motor rebuilt. The bike had an aftermarket Chinese CDI box on it, and the guy said that might be a problem with it starting. I had an '85 XR200R I bought first, and it had the CDI still on it, so I took it to him and he put it on, since I had no other options, I didn't know they were different, and money was tight.
The bike didn't wanna start. I found the pulse generator was 180 degrees out and valves way out, so I got that corrected. Bike will run but has been super hard to start since then.
My question is, when I put the correct CDI in, should it wanna start with ease? Like it's supposed to?!
Edited by Daniel627
Forgot some stuff
The Modules are unique for the engines they were designed for. The RFVC engines use a sensor on the flywheel that senses a protrusion on the flywheel and the CDI module contains the advance curve. The two valve motors use a sensor on the cam that senses a magnet with a mechanical advance. Each module has a product code mark so they are easy to identify.  The Product Code is the middle part of the part number, for the 86+ XR200R it is KT0.
Thank you thank you Chuck!!!
I went out and pulled the tank off my bike to look at the CDI module. Sure as shit is not the one I'm supposed to have. It has a KK0 on it.
Luckily, I pulled this off the '86 parts bike today. It's a KT0. :thumbsup:
I'm going out of town to work in a few days for 4-8 weeks, and when I get home, I'm slapping the whole setup in there! I hope that will be the make all the difference in the world and change it from 20-30 kicks, down to the normal Honda 2-3 kicks and get me riding all the time then.
1 person likes this
Posted (edited)
Update... I went out this evening, pulled the bike out of the garage, and swapped out the CDI modules. Put it all back together, turned the fuel on, hopped on the bike to kick and see if I could get it to start. Grabbed the throttle to try getting some gas in the carb, and, NO GO! :banghead:
I obviously forgot to drain the carb before parking it the last time I got it running. So the throttle needle is stuck. It's hot and humid and I don't have time to mess with it before I leave Sunday, so I'll clean and rebuild the carb when I get back from working out of town.
Edited by Daniel627
Typo
Forgot to include these pictures. Might be helpful for someone to recognize which CDI they should have.
20180713_204706.thumb.jpg.0a2c46d7c9502310e923702866586569.jpgKT0 is the smaller, '86+ 2 valve CDI module. KK0 is the larger '84-85 RFVC 4 valve CDI module. There is a considerable size difference, in case you somehow encounter one that doesn't have markings on the plug. Hope this is helpful to someone.
