On my 2008 rmz 450, at 1/4 throttle there's this horrible studder. It started about a month ago. The bike has about 70 hours on it i bought it later last year and never had a problem with it. The only thing that i changed on it was the header pipe it had the stock one and i tweaked it where it was making a weird noise so i replaced it with a stock one.
Things i have tried............................
New spark plug
Cleaned the air filter
Oil change
Checked the valves one exhaust is on the loose side but not out of spec.
I may try injector cleaner but idk if thats ok for these bikes.
Any help is appreciated thanks in advance
Check out the TPS. I had mine move on me after a weird crash that gave me similar symptoms. I loosened the screw and readjusted and had no issues after.
There is also a tach sensor by the stator that can go bad which will give similar issues. Having said that I have never personally seen an issue with one. Only ever seen it online.
