Crf250 won't idle dies when you give it throttle
There is a problem with my friends 06 crf250. It will start up and idle for a little bit and then stall. Turning on the choke makes it run longer but not by much then it stalls. Also, if you give it throttle to keep it from stalling it sputter and dies. The carb has been rebuilt, also all the Jets have been cleaned along with everything else. The tank had been emptied and filled with fresh gas. What could cause this?
