Case bushing alignment 2007 KX250 - does this look off?
How is the bushing pictured below supposed to fit in relation to the case surface? It almost looks like it's not pressed far enough in (sits about .5mm to the left of the case surface). Or, will it slide where it needs to be when I pull the case halves together? This is in a 2007 KX250 two stroke, got new case set from Kawasaki, old cases were cracked.
Edited by grits and sweet tea
