Help needed with LED blinkers
Hi guys and gals
I have an 08 DR650SE
I have just replaced the blinkers with LED blinkers, and also replaced the flasher unit under the seat. I was testing each light as I installed them one by one. And they were all okay until I got to the final signal, the front left turn.
Once installed the blinkers, when turned to go left, blink extremely slowly. And when switched on to go left all 4 light up.
I have also installed a Trailtech Vapor with led dash lights, and from the start, only the right turn would light up the single dash light.
Please help!!!!
Cheers
Shannon
Go to Pro Cycles site and read their install info.
It maybe you need a diode.
I've done my TW200, required a few different steps. My DRZ400 only needed a rather expensive flasher.
