WP shock service
Hello, I have purchased trax and am interested in learning how to do my own service now. It's time. I am completely green.
Is vacuum bleeder and nitrogen required? Will I need any other special tools/clamps etc? What setups are you guys running? I'm thinking I will run old paintball nitrogen tank and eBay reg with maybe the race tech adaptor and bleeder kit with harbor freight vacuum pump. Guessing about $800 all in...
 I would like to run the bare minimum (cheapest) setup right now, if I could make my own vacuum setup somehow that would save me a lot, thanks for suggestions! The cheapest one I found was 400 without adapters.
I would also appreciate any words of advice and what to look at regarding the trax shock!
http://www.shockbleeder.com/products/shock_bleeder_kits
Edited by Dirt Mcgurt
You need some special tools for the trax part ,is yours a pds or single piston ? Pds needs a vac pump
It's not ideal hand bleeding a trax, with only a 1mm bleed and a separater I would think it makes it hard, there are also a lot more parts n seals to change other than a normal shock, from needle shaft seals to seperator piston seals , by sound of it, mIght be best send it out to get it done, a lot of suspension companies strangely enough don't even service these properly, the older ones need springs every time in the trax unit also. A lot differant to a normal kyb to service
Edited by karlace
I am determined to learn how to service these properly myself, I am a competent mechanic once I learn something...
I really do too many hours on the bike to send it to someone... Just need some help getting started with advice on tools etc. I am willing to invest in nice tools but would like to get going with bare minimum during race season.. I am figuring about 1k u.s at the most which will for sure pay for itself.
Does anyone know if or where I can buy a trax service manual? I can not find one?
11 minutes ago, Officer Mike said:
Not to hijack, how do you like that trax compared to Stock? Thanks!
I just bought it and still needs serviced/charged and I'm sure a lot of setup and getting used to the trax action but I'll let u know.. It is supposedly valved pro desert and I ride woods so hopefully the adjusters have good range :excuseme:
Did you buy the one on eBay? I was looking at that one but ended up getting one off vital
Nice! Ya I was eyeing that eBay one for a while and ended up getting it on the 15% day, ended up being not much more than a revalve, I hope it's in decent shape :excuseme:
Whats your plans for the shock? Will you be sending it out or attempting service yourself?
Awesome. Mine shouldn't need to be serviced for a while, but I'm in socal so i will likely have WP or FC service it when the time comes. I hope you find the answers in this thread so I can hopefully learn how to do it myself eventually lol.
Would you mind posting the part number on yours? I believe it said it was for a 2014?
Not sure what the part number is. It said for 2015 and older.
I think I found a line on service manual but I will figure it out and post some answers eventually. Either no one knows or they being tight lipped, but I'm sure it's not rocket science lol
Ya so for ppl reading in the future the trax only needs 2 parts a bushing and seal that cost 25 bucks total 50180721 and 50180720 and u don't really need special tools for the trax other than something to clamp bottom circular clevis without damaging it. The circle housing part unthreads from clevis. No springs need replacing unless broken. WP will not sell their vise clamp tool or a service manual lol. I was told to clean and slather grease all up in there and that concludes trax service..
As far as shock service I believe the shock bleeder kit is the cheapest and easiest route rather than trying to build one fwiw and the owner is good people willing to help..
I was curious why this bumper appears to have been cut down? Can someone please explain why? I assume for more travel? Maybe something I should do to other shocks?
