2008 kx250f. Put a new piston and rings in. did everything how the manual says to. Valves are in spec. timing is correct. it bump starts easily and will run good except when i give it full throttle it will bog down/ die if i try to stay on it. But can not kick start it to save my life no matter what it is. Any suggestions would be greatly appreciated. thanks all!
