1996 kx250 Clutch Basket Question
will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
I've said this a million times.  If the part numbers are different then it probably won't fit, at least without modification.  Compare part numbers on any number of sites that sell OEM parts.
  • Like 3
I think it may have a different gear, not sure. The aftermarket baskets are the same, but they won't have the gear. I don't know if you can swap the OEM gears.
I am thinking the 1998 carb has some wires and parts (power jet? , solenoid?, not sure) that the 1996 does not. It might work, but not as well as intended.
