Carb drain screw
Does anybody know a company that sells tool free carburetor drain screws for a 2005 Suzuki drz 400, thanks for replying
Edited by Doug silva
Forgot type of bike
Free? No, nothing is free. I have to ask why? Draining a carb is something you might do once a year.
The drain screw on your BSR is a special tapered one. I've never seen a thumb screw for one.
The reason why is, I live on utila, a tiny island off the coast of Honduras, the quality of the fuel sucks hear, it's common to buy fuel with a bit of water in it, so, that's why I am searching for a tool less carb drain screw.
Great idea, but I don't own a brazing torch/gas setup and there are no machine shopshop on the island, I will find one, I feel confident that someone in the thumper talk world will let me know where I can purchase one
I want one for my CRF150R because it clogs easily if gas is left sitting. Couldn't find one. Probably just going to find a way to store a small screwdriver on the bike.
Jjktmrider, did you get my PM?
if this is for the 36mm mikuni bsr, I would be interested in 1 too, just because
Edited by 74jimbo
5 hours ago, jjktmrider said:
I'll look into making a couple if enough interest , otherwise I have more time programming for 1 minute per part making .
Great idea, I will like 4 please, the screw probably fits many different carbs
Fitting a few carbs is what I was thinking of checking out , hopefully many of the Mikuni's will be the same , fcrs will be different being a Keihin but are they the same as the CVK's , would be annoying if they all were different .  I have to think on something to make sure they can be tightened enough and stay there , don't know if a thumb screw knob will work and I don't want to be involved with a burnt up bike .
Jimbo I pm'd back the first message already .
Edited by jjktmrider
Maybe something similar to a wing nut would work good,  a wing screw?
2
I think my PM system is jacked up. I never got a response from you? Also, when I tried to send them, they did not seem to work right, or maybe they did? but my end only showed my name involved in the conversation
Edited by 74jimbo
If the screw had a head of about 12mm, was knurled it would easily be tightened securely. It takes very little pressure with a screw driver to tighten the screw ..its just a tapered seat.. Most folks over tighten them from what i see when I try and remove them.
Agree, most people over tighten them
Problem is when a person gets one that's been deformed from being overtightened , only way to seal them is by going tighter because the taper is already deformed. On my atv's/bikes that were bought new it's easy , but a lot used ones can be just snugged down normally and not drip , the older the bike ,the worse, even with new screws , which are usually a must due to messed up JIS or screwdriver slots from PO's . Now to make something to seal good enough just using fingertips , I know many that it would take more or be at the threshold of dripping with just a (13mm)1/2" knurled end . Then I have all those complaints of leaking or worse , almost need a preform tool to make the taper true again , then the drain screw. I have a pile of old carbs here , will have to play with some things , maybe a plastic tip or rubber at worst .
1 minute ago, jjktmrider said:
Problem is when a person gets one that's been deformed from being overtightened , only way to seal them is by going tighter because the taper is already deformed. On my atv's/bikes that were bought new it's easy , but very few used ones can be just snugged down and not drip , the older the worse, even with new screws , which are usually a must due to messed up JIS or screwdriver slots from PO's . Now to make something to seal good enough just using fingertips , I know many that it would take more or be at the threshold of dripping with just a 1/2" knurled end . Then I have all those complaints of leaking or worse , almost need a preform tool to make the taper true again , then the drain screw. I have a pile of old carbs here , will have to play with some things , maybe a plastic tip or rubber at worst .
Make it from 1/2 hard brass and it will seal.
Cant say I have had many at all of any brand, style or year that I had to "over" tighten to seal using a fresh drain screw.. I only work on a dozen or so bikes a week, so perhaps Im just not seeing these really bad ones that have to be torqued down to seal...but if I did, I wouldn't in any case, as if its not sealing with "normal" tq, its broke and needs to be repaired. .
When I do have one that leak with a new seal I clean the taper up in the carb body and sealing is again done with just light pressure.
I can buy a thumbscrew carb drain for the old Honda QA / mini trail 50, but don't know if will fit a stock drz carb, and people thanks for the ideas so far, please keep your thinking caps on
Keep it simple - Cable tie the correct screwdriver inside your airbox or behind headlight etc.  or anywhere it isn't going to fall off. Make sure u can still remove screwdriver without having to cut the cable tie. Then you will always have it when you need it.
if a klx250s part will fit (.6 x .75mm)  it uses a socket head.  Would be easy to cut down an allen wrench "L" and weld or epoxy it in for a handle ?
