Getting the clutch back in
I'm having trouble getting the clutch together after fixing my NSU bolt. I'm following this guide.
Everything is assembled, but the clutch lever feels light when being pulled in and doesn't return after.
The clutch arm is in the same position relative to the case as it was before.
The clutch release shaft is engaged with the spline shaft (rotating the spline shaft counterclockwise pushes the case out, can't rotate in clockwise, at least by hand).
