2003 Bear Tracker Electrical Problems
I have a 2003 Yamaha Bear Tracker and I cleaned the carb because Ite float was sticking. Also, it started just all of a sudden tot starting. Turn the switch on, push start and nothing happens! Neutral light not coming on, No fire at all to plug when you jump off by crossing solenoid with a screwdriver.  Starter turns over but no fire at all! Put in a new plug and still no spark! It acts like the switch has been turned off. I took switch off and contacts and wires looked new. I unplugged switch connector and cleaned with contact cleaner and put back together and nothing changed! Please help.
