BWard
DR 350 No compression
This is my first 4 strike and I need some help. I bought a 92 DR 350. I started it prior to buying it and it had a leak from the valve cover. I took the valve cover off and resealed with liquid gasket. Followed all the rules for letting cure. I didn’t mess with the valves or any internals. I put it back together and when I went to kick it over there was no compression. It feels like the decompression lever is engaged but it’s not. Also weird is that there is a port on the right side of the carb and every time i kick air shoots out of that port. Any thoughts what is going on?
First thing I'd do is get a service manual. Then get the right valve cover gaskets, o rings iirc, and adjust the valves to spec. If still no good make sure the cam is timed right and didn't jump a tooth. As for the carb, the manual should tell you what the port does. It's either fuel inlet or vent, either way air shouldn't blow out of it.
Go to ThisOldTractor.com for a service manual.
I find that if I leave my DR sitting for two-three weeks completely untouched, it'll "loose" compression. I can turn it over by hand, which makes starting a bit trickier.
I'll usually kick it over with the decompression lever open as fast as I can about 10 times, and then, with the choke fully open, it should build enough compression to start.
If I leave for a month or so, I just end up bump starting it. A smooth hill, neutral, decompression lever clicked in and then put it into second while rolling. Even if it just sputters it'll usually be enough to do the usual starting procedure.
I always found this weird, because the bike has good power, doesn't smoke and after starting has enough compression for me to stand on the kick lever.
Check the decompressor lever on the cylinder head is "loose"  - the cable should have a small amount of free play and the lever on the head should move a few mm freely. Otherwise it will be permanently opening one of the valves.
A more serious problem can occur if the engine has been burning oil for a while - carbon can build up on the valve seats and prevent them sealing properly (from experience with one of my DR's).
Edited by thedktor
You said there's puffs of air coming out of the head on the right side? The bolt on the side of the head could be missing, or your head gasket could be blown. image.png.32a8d96890e2fbc2d4bfacd7db7b6b25.png
