Steve Wagner
XR100R 1985 no fire
To check the crank, just look for circular marks on the taper.  There should be zero marks.  Plus you can see damage on the flywheel as it spins around the key.  But, if it's not backfiring, it's probably didn't spin. If it gives you much more of a headache, you can easily swap it for a CDI ignition.
Edited by socalxr
On 9/30/2018 at 11:50 PM, Alexxxx said:
What number is stamped on the flywheel?
F130- ??
F130 is stamped on flywheel. Installed a new aftermarket carb on it, and switched spark plug cap to a resister cap and she runs!! Idles ok but at full throttle it wants to stall and backfire and lose power. So some fine tuning to be done there.
Thanks again to everyone’s help. I’m sure as I get deeper into this project I will have many more questions
Just wanted to ensure you got the correct flywheel F130-58 for XR100 and not F130-54 for XR80 with different timing marks.
Now that your engine is running, it's important to check ignition timing with a timing/strob light. That is extremely important because even small deviations lead to the above described running symptoms.
When timing is done you may think about the carb and other things.
Btw., the engine runs with or without resistor(s) in spark plug or cap. That resistor is only to eliminate distortions in electronic devices at the environment.
There are lots of faulty plugs and caps out there, even new ones.
Edited by Alexxxx
I think it is 130-58. I do need to fine tune the timing. When I got it going it started clicking under the valve cover. Shut it down and removed the cover to find the cam chain sprocket had loosened. Tightened the sprocket but now I think cam chain is loose. Didn’t have time to investigate further but will have to look at before starting up again
When the cam chain sprocket loosened it resulted in the woodruff key getting sheared and messed the timing. Got a new key and learned the hard way I need to torque the flywheel nut before I ride the bike, sheared the damn key again. Before it sheared the key it was running well but does feel like the clutch slips. Revs up but power stops making it to the rear wheel.
Woodruff, clutch, fork seals, steering head bearings and rear shock bearing and she should be good to go.
  • Similar Content
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
    • By Wayno50
      Nostalgically bought this bike because it’s same model/year/size of what I had as a kid in the early 90s. I should have looked closer but was blind to its issues. Kid before removed tailpipe and put on a silly silencer which I just threw in the trash. Thankfully he kept track of OEM tail pipe but cut the end off of it.. I can only guess to make it louder. I have pipe back on bike but back pressure not good and sound not as tight as it should be. Does this need packing? Can I get a retrofit tip for the jagged 3” end?
