what carb is this?? fcr?? cv??
1 hour ago, thebugslaaaa said:
hey guys, looking at picking up a new carb to replace stock sm carb...what am I looking at here? fcr?? or newer E carb?
It is an FCR slant
It might be a 39 or a 42mm bore.
The bell may or may not be the correct size, but it does have the vacuum port an E bell does.
It may or may not be worn out ...at the throttle shaft to body or where the slide rollers contact.
It may or may not have the tip of a broken fuel screw stick in the body.
It may or may not have stripped threads in the float bowl screw holes.
31 minutes ago, Erik Marquez said:
It is an FCR slant
Ya i figured as much guys...sounds like more trouble than it may be worth...
