Matt Champion
XR200R Cam options
Has anyone here used the Webb Cams 214 grind for XR200R?  Thinking of using it in a hot trail build... 11:1 CR, mild port job and pipe. Aiming for good torque and useable power.
Terry Miller was going to supply me with what he called a '714 Torque Cam' but that hasn't happened so looking for an alternative?
Grind:214 Intake/Exhaust Valve Lash (Inch): .004".004"    Valve Lift (Inch):0.375  0.375     Valve Lift (mm): 9.53  9.53   Advertised Duration:280° 280°  Duration @ 0.050":250° 250°        Lobe Center:106° 106°
Intake Opens 19°BeforeTDC
Intake Closes: 51°After BDC
Exhaust Opens: 51°Before BDC
Exhaust Closes 19° After TDC
I haven't used it, but 280 is a lot of duration (not good for torque). I wouldn't use it unless I go bigger on displacement and 12+ compression, otherwise it will probably kill some bottom end. Should have good top end if properly ported though.
I have the 714 cam but haven't put it in my 200 yet because I've been too busy riding my 230.
I've used the stock cam, 714, and Torque cam in Powroll 218 w/ 11:1. Several back to back observations:
A stock engine runs smoother than the 218s but in comparison it needs to be revved, always one gear lower, and you always seem to be waiting for the revs to build when exiting a corner. The 218 Torque cam gets you accelerating as soon as you add throttle.
The 218 with stock cam vs the 218 engine with Torque cam seems OK, only slightly softer than the torque cam, but it is running one less tooth on the counter shaft.
714 vs Torque cams; not back to back because used in same 218 engine. I've done this comparison test twice because when I built the 218 I had to wait for the Torque cam so I used the 714. Same situation when I rebuilt the engine because of a lube failure. The 714 is softer on the bottom but pulls better on the top.
I trail ride, often in tight and gnarly, so the Torque cam is my choice. After you adjust to the power delivery of the Torque cam the others feel soft on the bottom.
The Torque cam in a Powroll 218 w/ 11:1 produces more torque than a dry sump XR250R, and my little XR is 45lbs lighter.
The biggest difference in the aftermarket cams is the much higher lift than stock and the more aggressive lift rates, results in more gas flow.  So if the duration and overlap are much more than stock you lose bottom end. The 200 doesn't have the displacement for bottom end like larger engines so not good to cam for less.
The 214 is more of an all out cam.  High compression, big displacement, head work, big carb are going to be needed to take advantage of it.
I settled on the 89a as a good, but less crazy option.
Posted (edited)
Here is a XR cam summary I put together a few years ago:
Edited by Chuck.
Thanks for the replies. Made me realize that the 214 was way too much cam for my motor! I have ordered a 389a, springs and hardweld rockers from Web-Cam and will run this until, hopefully, Terry Miller comes through with the torque cam.
  • Similar Content
    • By Daniel627
      A while back I picked up a '95 XR250R swingarm that I plan on installing on my '90 XR200R in the near future, to save a little weight and have rear disk brakes.
      I missed out on a totally complete rear brake system for $75 a while back which sucks. I look on Ebay every now and then hoping to find a great deal on a complete or near complete setup but no luck lately.
      Is anyone aware if Honda used the same brake system that was used on the '90-'95 XR250R, on any other bikes?
      If so, then I can expand my search. If not, then I'll just keep looking at 250 parts til I find the right setup for the right price.
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
